[HELP!] Connecting front USB 3.0 to back
rajandeep123
90
Hi
This is my second time asking this and I hope I can get a helpful reply this time.
Its my first build and I an choosing a cabinet. I came across Corsair 200r but it has 2 USB 3.0 ports and my mobo doesn't have ÚSB 3.0 headers while the case requires 2. My mobo, however, has 2 USB 3.0 ports in the back. Is there a way that I can connect those to the front of my PC?
Thank You
Yeah. that only has USB 2.0 internal headers. Check with corsair on if you can connect the back panel USB to the front panel on the case you mentioned.
With that case I'm not sure. A lot of cases do have front USB 3.0 ports that comes with extra cables which are basicly USB extension cables that you connect to the back and goes to the front. With your case though I'm not sure if it has this. So maybe just contact Corsair or check with a retailer who has this case and see if it does support the extension cable
