[SOLVED] Help connecting the USB case wiring to the motherboard...
Richard67
Commendable
Feb 17, 2019
24
Hello,
I need some help connecting my motherboard to the front panel USB slots on the case.
My motherboard is: Gigabyte Intel B460 D3H Micro-ATX Motherboard (Revision 1.0). The manual for the motherboard is: https://www.gigabyte.com/uk/Motherboard/B460M-D3H-rev-10/support#support-manual
My case is: the Corsair Carbide 100R. The manual for the case can be found at: https://www.corsair.com/corsairmedia/sys_master/productcontent/WW_100R_QSG_AB.pdf
Is that enough information?
Thanks in advance,
Richard Lindley
Turns out I just needed to plug it in. There are two sets of USB connectors and I didn't see the right one. Dummy (me)!!
Thanks for the help anyway. Problem solved!
