D Devin_ Reputable Oct 4, 2015 14 0 4,510 Jan 21, 2016 #1 So I have an Amd A10 6700 and overdrive said my cpu temp was 16 degrees where its 102 on Cpuid hwmonitor Help me
Solution rolli59 Jan 21, 2016 Check your BIOS on startup! 103 and it should have shut down, 16 is under ambient for most so not believable.
rolli59 Titan Oct 27, 2007 47,806 287 130,890 Jan 21, 2016 Solution #2 Check your BIOS on startup! 103 and it should have shut down, 16 is under ambient for most so not believable. Upvote 0 Downvote Solution
rolli59 Titan Oct 27, 2007 47,806 287 130,890 Jan 21, 2016 #4 Enter BIOS on startup and you should have hardware tab. Differs between manufacturers but many have Del (ete) key or F2 to enter BIOS/Setup. Upvote 0 Downvote
