Help - CPU-Z says my DRAM Frequency is at: 686MHz. Is this normal?
Just remember, cpu z shows half the speed of your original memory. if you have 1866, it should say 933. i have a 1600 mhz set and it shows me 800 mhz, it is normal.
Before I do that, I followed this guide:
http://www.overclockers.com/forums/showthread.php/693613-Beginners-How-to-set-your-25-6-700K-to-4-5Ghz
It had me change XMP in Overclock Tuner to Manual and I modified the values for Voltage (which I read if you do XMP, you should do Voltage Auto).
What is your take on this?
So 686MHz is okay for 1866 ...? Mine is much lower than 933.
