help cutting cost on first build
Psuf26
5
specced out my first self built gaming PC. really wanted to keep the cost below £750 (about $1200) currently £100($150) over
can anyone suggest ways of cutting costs without losing performance. other suggestions welcome
http://uk.pcpartpicker.com/p/74WHD3
thanks in advance, let me know if i should move the post somewhere else
Here it is, I changed the CPU to a i5-4690k which has much better performance than the FX 8350. I've lowered the RAM to 8 GB's total, you dont need 16 GB for gaming, and I've chosen a better PSU.
http://uk.pcpartpicker.com/p/hJJhJx
You have another option, which I consider to be a better one. You remove the SSD and buy a 280x instead of the 270x. You can buy the SSD later on. http://uk.pcpartpicker.com/p/Kb7Kgs
It would give you a better performance in gaming, and practically, it's better adding an SSD later than replacing the GPU.
both of those look solid options, thanks, with the second option would i not be better with an SSD and add the standard hdd when i have more funds? as id want the OS etc running on the ssd
also ny alternative ram suggestions or is that the best 8gb set up for the money.
i think i will try and get the 280x in there, i like the case you have put in, do not know how i missed that one
Better to buy 4590 than 4690k with that PCMate mobo.
CPU: Intel Core i5-4590 3.3GHz Quad-Core Processor (£154.98 @ Novatech)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (£24.98 @ Novatech)
Motherboard: Gigabyte GA-H97M-D3H Micro ATX LGA1150 Motherboard (£70.76 @ Scan.co.uk)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory (£41.94 @ Aria PC)
Storage: Samsung 850 EVO-Series 120GB 2.5" Solid State Drive (£52.20 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£43.38 @ Amazon UK)
Video Card: XFX Radeon R9 280X 3GB Black Edition Double Dissipation Video Card (£175.98 @ Scan.co.uk)
Case: Corsair SPEC-03 Red ATX Mid Tower Case (£45.80 @ Aria PC)
Power Supply: Antec High Current Gamer 750W 80+ Bronze Certified ATX Power Supply (£58.57 @ Scan.co.uk)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) (£76.50 @ Amazon UK)
Wireless Network Adapter: Gigabyte GC-WB867D-I 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter (£29.99 @ CCL Computers)
Total: £775.08
Generated by PCPartPicker 2015-04-28 22:17 BST+0100
You can drop ~16 pounds by going MSI card instead of XFX and Win7 instead of Win8.1
Your choice, but you wont have much space for some time, only 120 GB. You cant install many games on that.
Corsair Vengeance is one the best RAM for the money/performance ratio.
Good luck with your build.
