Help decide between 3 diffrent GPU's
JK7521
80
I was wondering which GPU you guys would prefer, its up between the EVGA GeForce GTX 660 http://www.amazon.com/EVGA-GeForce-SUPERCLOCKED-Graphics-02G-P4-2662-KR/dp/B00966IREK/ref=sr_1_1?s=pc&ie=UTF8&qid=1393197591&sr=1-1&keywords=geforce+gtx+660
, GIGABYTE GV-N660OC-2GD GeForce GTX 660 http://www.newegg.com/Product/Product.aspx?Item=N82E16814125443 , and MSI N660 Gaming 2GD5/OC GeForce GTX 660 http://www.newegg.com/Product/Product.aspx?Item=N82E16814127756 . The main reason I chose these three GPU's is because of my build and budget. I will mainly be using my pc for moderate gaming, VMware workstation, and adobe applications. The Gigabyte and msi ones I like because they have an open design and will allow better airflow. But I also want to start making youtube videos of everyday things and also my gaming footage. I noticed that the msi one comes with EXPERIENCE - PREDATOR and was wondering if this is good for the youtube videos I want to make? or if I should look into other software to get the job done and if so what software would you recommend?
all 660's will support the same technology. the msi thing is just a software that you can download for free anyways. that said, just buy the one you like the best, as they are all roughly the same performance
Latest posts
