Help deciding 19inch LCD
apra143
4
Was hoping I could get some advice on the following 19inch LCDs (ignoring the price, since they are about the same). I have listed them in order of preference from what I've read and gathered from the specs and some online reviews.
Good quality gaming (e.g. CS:S) and vids with them would be preferable - for home use. These are shopbot links (from Australia) so that you can see the specs and prices at a glance. Any thoughts on my choices would be great.
http://www.shopbot.com.au/p-32860.html Philips 190CW7CS
http://www.shopbot.com.au/p-29541.html LG L194WT - has LIPS (LCD Integrated Power Supply), is it any good?
http://www.shopbot.com.au/p-24730.html ASUS VW192T
http://www.shopbot.com.au/p-24731.html ASUS VW192S
http://www.shopbot.com.au/p-36779.html CMV 946D
http://www.shopbot.com.au/p-26401.html BenQ FP92W
http://www.shopbot.com.au/p-20022.html CMV 938D
Cheers.
Thanks for reply.
The Viewsonic VX922 is around $150 more than the others I've selected, and spec-wise the Chimei CMV 946D seems to be similar or better (e.g. viewing angles) - but I can't seem to find data sheets to confirm if the 2ms RT is grey-grey for the CMV 946D.
Or is comparing widescreen LCDs to non-widescreen unfair and/or pointless?
I'll be doing a lot of uni work and some gaming + movies, thought widescreen would be better?
How about the VP191b then?
That's even more expensive and only 8ms.
The VP191b is around $300 http://www.shopbot.com.au/default.asp?kw=VP191b&position=search
Shopbot cannot find that model (look carefully at the search results).
There's only one vendor that I can find matching that model:
http://www.staticice.com.au/cgi-bin/search.cgi?q=VP191b
and it's listed as $993.72
I'm more interested in comparisons between the models I've selected in the original post; particularily the CMV 946D.
And where possible, I try to get manufacturer data sheets, which I can't find for the CMV 946D 🙁
Thanks.
