Help deciding between 7820x or a 2920x
Dec 4, 2018
4
Hi all!
I have a 7820x build that I put together before threadripper came out. Now my x299 board is slowly diying, so I figured I should look into AMD. My wife uses it to run multiple virtual machines that run genetic sequencing. The VMs are very memory intensive, so will moving to the 2920x with its memory frequency at 2937mhz be more efficient than staying with the 7820x? I also game on it with the VMs running in the back ground. We have the intention of going up to 128gb of ram soon.
CPU 7820x
MB Gigabyte aorus x299 gaming 7
TridentZ rgb 3000mhz 64gb
EVGA RTX 2070 xc ultra
M.2 Samsung 950 pro 512gb
Intel opthane pcie ssd 400gb
Seagate 2tb 5400 rpm hdd
Custom built water loop on cpu
EVGA 850w supernova gold+
Yeah, I think I'm going to go with the x399 build. After all the problems I'm having with this MB, and all the problems that I've read about with x299 boards it just might be a better option. I am however going to stay away from Gigabyte for a while.
