Title says it. First time building myself, and need some help on what to get. I received an amd APU (A8-5600K) and a GPU (R7850) a while back, so deciding to build the rest. Primarily trying to decide what motherboard to get right now, but will need to figure out PSU and RAM eventually. In terms of games I might play, Portal 2, CS:GO, Bioshock series and the like come to mind.
The CPU is an FM2 Socket, so that narrows it down. My casing fits ATX and microATX, narrowing neweggs filters to 43! -_- Would an ATX board be cheaper than the equivalent microATX board? I'm currently leaning to a microATX so I could move it to one of my smaller cases in the future if I build another system, but better performance at a similar price would sway me one way or the other. I doubt I'll be getting any additional graphics cards or Crossfiring, so an excess of PCIex slots won't be necessary. Won't be needing integrated graphics. I may consider putting in a wireless card for convenience if the price is right (<$10), otherwise I'd just be using a long ethernet chord, what kind of slot would be necessary for that? Ideally I would want to spend <$100 on the MB, unless there anything else I should consider/is worthwhile? I don'e quite understand the difference in chipsets, are they just different additional features? Or do they affect performance? Not trying to break the bank with a free processor haha. Recommendations please!
Considering this PSU:
http://slickdeals.net/permadeal/96536/tigerdirect-850w-hec-80-silver-certified-power-supply
It appears to be no name, but seems like a steal for the voltage. The R7850 says 500v recommended, is that for the GPU alone, or overall? Would it be better to have some overhead voltage? Or should I go for more known brands like corsair?
As for RAM, I'm considering just 2x2gb=4gb, would 2x4gb=8gb improve performance by much? I hear games wouldn't utilize it all anyway, and the most multitasking intensive thing I would be doing is having 20tabs on chrome with a couple word docs and/or spreadsheets open.
Parts I already have:
CPU: AMD A8-5600K 3.6GHz Quad-Core Processor Black Edition
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113281
GPU: R7850 Twin Frozr 2GD5/OC
http://us.msi.com/product/vga/R7850-Twin-Frozr-2GD5-OC.html
Storage: 120gb hdd
Case: Cooler Master Centurion 5
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119068
Approximate Purchase Date: Sometime in the next month, no rush.
Budget Range: 200-300 tops (for the parts I still need) After Rebates & After Shipping
System Usage: Daily work/school usage, surfing internet, watching/streaming HD movies (HTPC maybe), occasional gaming (maybe more if build turns out well)
Parts to Upgrade: MoBo, RAM, power supply (have old stock 350w from Cooler Master Centurion 5, likely no enough for this build)
Preferred Website(s) for Parts: newegg.com, tigerdirect.com, amazon.com, frys.com. Cheaper the better! I've been comparing parts on newegg, will probably scour for deals once I decide on parts.
Overclocking: Never done it before, but might this time. Likely, since I've read the CPU might bottleneck the GPU.
SLI or Crossfire: Probably not.
Your Monitor Resolution: 1440x900, 1600x900, maybe 1920x1080
And Most Importantly, Why Are You Upgrading: Currently running a 3.0ghz Pentium 4 system from circa 2005, so anything would be an improvement. Mostly need something snappy and responsive.
Storage: 120gb hdd
