I have a budget of 80~150 to decide on a new AMD motherboard for a AMD FX-8320 processor that will be used.
I use VMware virtual machines a lot and have them running at least everyday. I do encryption of devices often and depend on programs that utilize 100% of the CPU.
I sometimes do gaming, but it's not the primary focus of my usage. I'm not sure which motherboard would be best for the FX-8320, because reliability and SATA 3.0 ports are a need for me.
My questions really are:
1) What would be a good motherboard that is known to be reliable and work best with the AMD FX-8320?
2) Does the chipset on the motherboard matter when it comes to the CPU and performance I get out of it?
3) Are there specific motherboards that accept water-cooling solutions better in terms of mounting space?
4) Is there a better 8-core processor I should get instead of the AMD FX-8320 around the same price point?
5) is there a best thermal grease to use for the FX-8320 to provide better cooling over other greases?
