Help deciding on a printer
palves
25
Hi,
I need to buy a home colour printer, scanner is important but it is basically a home printer. I am looking for a relatively cheap maintenance and low cost printing.
My HP 6830 is broken and ink cartridges were annoying as the printer refused to work with no-brand cartridges (I tried 6 different alternatives and only original HP)...
So basically, colour + scanner + lowcost cartridges or laser, branded or not.
Any suggestion.
Thanks a million.
PA
Get a laser printer : will alleviate a lot of issues and you get way better millage with toners than rip-off ink cartridge.
If you still want to stick to ink, I recommended brother printers. Cheap yet efficient. Won't waste as much inks as other brand when cleaning. Usually easy to get cheaper non branded ink.
