I'll just give a brief run down of my problem.
When using my custom pc my GPU (EVGA GT 630) rattles and vibrates causing an awful noice! I have noticed that one of the blades has broken off and was wandering whether that might be the cause. I have touched the card, holding my finger on it, and that absorbs the noice and have also used the wires in my case to try and anchor it down (but the pcb has cracked slightly because of this). Also to note, the inside of my case is upside down to normal cases, so the heatsink of the gpu is facing up.
I would just like to know you guys thoughts, and any suggestions.
Thanks in advance!
Thanks in advance!
