help: default directory path for xp pro SP2
Happy
117
Archived from groups: microsoft.public.windowsxp.help_and_support (More info?)
hi, i need help how to set the default directory path when installing
softwares . When im installing a software, the hard drive directory path
always appears the main directory path which is C: but i want the default
directory path to be D:
Is it possible to do what i want? or i have to decide where the files go
when im installing softwares.
Can anyone tell me how to set the default directory path from C: to D:
Much Appreciated. Thanks
G
Guest
Guest
> path always appears the main directory path which is C: but i want
> the default directory path to be D:
> go when im installing softwares.
Do you actually install software so often that manually selecting the D:
drive during the install becomes tiresome?
Most of the time - honestly - the path it gives you as default is the
program choosing it based of environment variables you SHOULD NOT change -
like %SystemDrive% and the likes. So it is the applications poor
programming - not necesarily the OS - that causes you the grief.
Shenan Stanley
MS-MVP
How To Ask Questions The Smart Way
http://www.catb.org/~esr/faqs/smart-questions.html
G
Guest
Guest
"Happy" <cathypham@sympatico.ca> wrote in message
news:4_wLe.17253$yH2.921488@news20.bellglobal.com...
Change the value of "ProgramFilesDir" to whatever directory you would like
at this location in the registry:
HKLM\Software\Microsoft\Windows\CurrentVersion
William
Thread starter Similar threads Forum Replies Date
T Windows XP 2
Similar threads
