I am looking to design a desktop computer that can handle pretty much any game you can throw at it. With that being said, I am a college student and am kinda broke, so keeping it lower on the price range is ideal (around $1000-$1300).
So far I really just searched around and found components that had good ratings, but I don't really even know if they are compatible or if they would be a good choice. If y'all could give me some helpful feedback and criticism I would really appreciate it. Also, I am eager to learn as much as I can, so if you use any acronyms or terms that are less known, please elaborate.
Here is what I have so far.
MotherBoard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128707&cm_re=motherboard-_-13-128-707-_-Product
or maybe
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157501&cm_re=motherboard-_-13-157-501-_-Product
CPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284&cm_re=cpu-_-19-113-284-_-Product
Video Card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130932&cm_re=graphics_cards_for_desktop-_-14-130-932-_-Product
or maybe
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121855&cm_re=graphics_cards_for_desktop-_-14-121-855-_-Product
Hard Drive:
http://www.newegg.com/Product/Product.aspx?Item=N82E16822145912
Heat Sink:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&cm_re=heat_sink-_-35-103-065-_-Product
I haven't selected a power supply yet or a tower and I am actually not sure what else I'll need. Please feel free to offer any suggestions.
Thank you very much!
MotherBoard:
or maybe
CPU:
Video Card:
or maybe
Hard Drive:
Heat Sink:
