Hi! I'm hoping to get some ideas about why a graphics card would be running way too fast and hot.
I have a brand new build and I have two of the exact same graphics cards, ASUS Rog Strict GTX 980. (Only using one card in the system, I just happen to have two on hand)
When I run one if them it works as it should. Cool and fairly quiet even under medium to heavy load. The other one, however, seems to be working really hard under the same conditions. As soon as I start a game the fans speed up to 100% and the temperature increases pretty rapidly. I only let it get up to 80 degrees c before I shut it down but my bet is that it would have kept climbing.
I can pretty much rule out any sort of driver or software issue as well as any issues with other hardware since the other identical card works fine.
I opened up the problem card to see if there was anything obvious. It was very clean on the inside. The only thing that looks a little off is that there is some excess thermal paste around the outside of the chip. Seems unlikely that that would cause the problem I am having, but could it?
Any ideas on what could be the cause and how might fix it?
Thanks!!!!!!
Thanks!!!!!!
