I'm trying to find out what's causing my BSODs.
Here's a picture of the Event Viewer summary: View: https://imgur.com/a/gD2PEXq
I know the BSOSs are bad and I should try and figure out what's causing them but do the amount of errors and warnings look normal? The look to be quite high to me but I'm not sure.
One of the issues I have with diagnosing my BSODs is that they are the "quick BSOD" type where the BSOD flashes for about 1/4 of a second and then the system reboots. So I can't read any information on the blue screen.
And another issue is that my system is not making logs of any of the BSODs. So BSOD viewers are useless. I suspect this is because of the type of BSOD. It says in event viewer "Dump file creation failed due to error during dump creation."
Here's a pic of the detailed critical errors in Event Viewer: View: https://imgur.com/a/Nt1Ov45
Notice that they are all the same.
Here's a pic of what event viewer looks like in the lead up to a BSOD: View: https://imgur.com/a/wPbKdg8
Notice that it says "The previous system shutdown at 5:50:29 AM on 17/08/2020 was unexpected."
I've noticed that this tends to be the pattern before a BSOD, it says the previous system shutdown was unexpected but, I am always shutting down my PC by using the Shut Down in Windows.
Anyone got any idea where I should start with diagnosing this?
