Question help dial in voltage please on my 2600x
DREDKNOT_2077
115
help dial in voltage please im tring to set 1.4volts on the vcore for my amd 2600x at 4.075 - 4.1ghz
my core gear is
cpu - 2600x oc to 4.075ghz
mobo - gigabyte AORUS B450M
ram - 2 x Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3200 CL16
with these volt settings
Dynamic Vcore(DVID) +0.234**
Dynamic VCORE SOC(DVID) +0.030
DRAM Voltage (CH A/B) 1.330V
an i cant tell if im getting it right
i have tried both global c states both enabled an disabled an auto
it seems more stable with c stats disabled but at the boot bios screen
it reads a peak of 1.380 volts but at main screen it looks like im getting 1.46
View: https://imgur.com/gallery/jvEFWeC
under the gnome extension vitals iv cant tell how to read which volt
reading refers to the vcore volts reading help me with this please
help dial in voltage please im tring to set 1.4volts on the vcore for my 2600x at 4.075 - 4.1ghz
my mobo is the aorus b450m
with vcore set at .215volts
it reads 1.380 volts but at main screen it looks like im getting 1.46
Voltage changes with load unless you set it manually in BIOS.
