Help Dimensions 4600
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
Guys I have messed up big time...
I have just tried to add a second hard drive to the above.
Now I cant get the Dimensions to find the Primary drive,
I keep on getting 'Primary drive not found'
Ok I have tried different configurations on the BIOS and the jumpers on my
Hitachi Deskstar.
Any help would be appreciated.
ShiftZZ
G
Guest
Guest
"shiftzz" <shiftzz@bbb.bb> wrote in message
news:W5V4e.11971$il.7797@newsfe5-win.ntli.net...
> Hitachi Deskstar.
Put both drives in Cable Select mode with the jumpers. Make sure you
primary drive is at the end of the IDE cable. Set the BIOS to Auto for the
two drives and then reboot.
If that doesn't work try the Master Slave jumpers with you primary disk
being jumped as master and you new secondary disk as slave.
If all else fails put it back the way it was before you tired to install the
new disk and then add the new disk to the secondary IDE channel following
the same jumper pattern described above.
HTH
Rob
G
Guest
Guest
also make sure the ide cable is firmly seated into the motherboard
connector. you might have loosened it. also check that the power
connectors to the drives are firmly connected.
> Hitachi Deskstar.
> ShiftZZ
G
Guest
Guest
Thanks guys....
Now working . Yipeeeeeeee
ShiftZZ
"ZupaDupa" <ZupaDupa@DupaZupa.com> wrote in message
news:5h25e.1939$oR.367@fe04.lga...
>> my
>> Hitachi Deskstar.
>> ShiftZZ
G
Guest
Guest
wonderful! so what was it???!!!! the suspense is killing me... ;-)
"ShiftZZ" <nomail@nomail.com> wrote in message
news:iX35e.11778$pA6.6025@newsfe1-win.ntli.net...
> Thanks guys....
> ShiftZZ
> >> my
> >> Hitachi Deskstar.
> >> ShiftZZ
