I am planning on replacing my stock fan because months prior there used to be a noise like it was scratching against something (originally I thought it was the harddrive which it wasn't). Now it is at a point where I have to have the case open and wind the thing to life and it takes a minute to reach up to the appropriate rpm (1500-2600). Now I am just asking if this is SOLELY the fan at fault or could something else be wrong in addition?
Also any recommendations for a cheap aftermarket cpu cooler or cpu fan replacement (Note the heatsink is fine)? I rather not deal with any liquid cooling since I do not plan to overclock my FX6300.
EDIT: I forgot to mention that any replacement that has a heatsink with it would need to be so the fan is aiming perpendicular from the cpu into the other side of case where there is a vent.
