Help downloading asus aura
Dhermesh
Commendable
Oct 26, 2016
24
I went to the Asus website and tried to download asus aura, but for some reason i cant run the file, it downloads a .zip file that i can not open or run. I have a maximus ix hero mobo.
Thanks in advance
This should be easy actually...
Download from here. Make sure you choose the correct OS and Bit-version. The AURA-Software can be found in the "Utilities"-category.
After that you should be able to extraxt the .zip file using a software like Winrar or 7-zip or any other of your choice.
In the extracted folder there should be an executable file, which you should be able to run and install AURA with.
Where exactly do you encounter problems doing that?
Even easier would be an installation via CD if you recieved one with your ASUS product.
