G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.hardware.chips (More info?)
I am a little confused with this terminology and could not find
much information in AMD site.
I would like to confirm (or be corrected on) the following:
1) It is my impression that these dual-core Opterons are *truly*
two processors in one physical casing. That is, plus/minus
any external interface circuitry, or bus controller, etc. to
coordinate/synchronize the two CPUs. Also, perhaps they do
share the L2 cache? (as I understand, each of the two CPUs
has its own 64k+64k L1 cache -- correct?)
2) If, for instance, I am going to install Linux on a dual-core
Opteron beast, then I would use the SMP kernel (IOW, a dual-
core chip provides indeed an SMP architecture)
My confusion comes when I read about the 1-way, 2-way, etc.
models. It has always been my impression that N-way refers to
the number of processors in an SMP architecture. Shouldn't
the minimum N for a dual-core be 2? I mean, it sounds as
though the N in N-way refers to the number of chips we put
(i.e., the number of CPU sockets on the motherboard). Is
that the case? (doesn't make a lot of sense to me, but if
that's what it is, I would like to know it)
Please clarify these concepts. The uncertainty is killing me
Regards,
-Mike
Regards,
-Mike
