G
Guest
Guest
Archived from groups: alt.sys.pc-clone.gateway2000 (More info?)
I have ask this question in the Symantec NG with no response and I have look
in the knowledge base on their web site to no avail. If you or anyone else
could answer this question I would greatly appreciate it.
I have Norton System works 2003 with internet security. Recently Internet
Explorer would not open pop-up windows, (hyperlinks opening in a separate
window). So I installed Mozilla and Netscape, so now when I get an
intrusion warning I can not run the visual trace. The visual trace tries to
open in IE 6.0 and locks up. How do you change the program visual trace
uses, I have tried changing the file types through windows explorer, but
have not found the right file extension.
Thank you in advance.
-LJ
-LJ
