Help! External hard drive no longer recognised by the PC.
Nov 30, 2017
Since yesterday my Seagate 2TB external hard drive (Model: SRD0NF1) could no longer be recognised by the PC, the indicator light is not light up either.
However, the hard drive does still produce heat and there is quite a bit of vibration when connected. Also, this disk can be found in the Disk Management, as "Disk 1, Unknown, 1863.02GB Unallocated, Not Initialised"
When I tried to initialise it through either MBR or GPT, a window called "Virtual Disk Manager" would pop up, stating "Data error (cyclic redundancy check)."
The external hard drive can also be found by data recovery softwares, as "Lost Partition-1". I tried to run a deep scan using a software called "EaseUS Data Recovery Wizard", but the scan could not be finished and no file was found.
Do I have a chance to get this external hard drive working again?
"... "Disk 1, Unknown, 1863.02GB Unallocated, Not Initialised"...
I'm hoping something like MiniTool or EaseUS or AOMEI or whatever partition manager can bring back the errant (presently missing) partiton -- that's my first wild guess as to what to try.
