I'm water cooling my i7-7700k and GTX 1080 TI. This is my first time water cooling and I think I may need a bit of help with the layout I'm using, plus I have a couple of other questions.
First off, I already attempted to bend and install my PETG 1/2 - 5/8 primochill tubing, and it was basically a disaster. Way too many mistakes and when I went to fill it realized that I had way too many leaks. Luckily, nothing leaked on any hardware. I bought double the tubing I initially had and I am going to try again, this time a little wiser.
Anyway, my tube layout is below. Will this work? Is the pump/res to tube res okay? When I tried to fill my loop previously, the water was not pumping to the upper left tube sections (the cpu and gpu). Maybe I was filling it wrong? What would be the best way to fill this loop? I tried to fill the photon as much as possible, then I turned the case on its front and filled the bay res as much as I could. Then I jumped the psu with a paper clip and tried to run the pump, which it did. But, like I said the pump was having trouble going up. Here are my questions:
1) Should I use the top fill port on the 270 photon as an inlet instead of having both the inlet and outlet on the bottom? How would I fill the loop if I have tubing going to the top?
2) Do I need another D5 pump?
3) Do you have any tips on how to accurately measure and bend PETG tubing?
4) Should I make any other changes to my proposed layout?
