HELP FINDING 3 PIN CONNECTORS on Motherboard
NewPCBuilder101
Commendable
Nov 29, 2016
23
GIGABYTE GA-H110M-S2H Intel H110 (Socket 1151) Micro ATX
I want to connect 2 fans to my motherboard but I don't know where there 3 pin connectors are located, if someone can kindly locate them for me, I would appreciate it.
If possible use the following image and put a square around the areas where there are 3 pin connectors, thanks.
http://www.gigabyte.com/fileupload/product/2/5606/20150...
The thing is that I don't have the motherboard yet so I was wondering if anyone knew before hand
Also, do you know any splitters I can use which can be bought from amazon so I able to use 3 pin connector on a 4 pin adapter cable
Board's manual is on Gigabyte's website: http://www.gigabyte.com/products/product-page.aspx?pid=5606#manual
It has locations and numbers of all the connectors on the board.
Just in case you were not aware, 4 pin fan headers are compatible with 3 pin fans (though they may not be controllable).
So, to connect two 3 pin fans, am I able to use this splitter? https://www.amazon.co.uk/Akasa-AK-CBFA04-15-Splitter-Ca...
