Question Help finding a CO2 adapter ?
Does it work
222
34
4,640
Pointless and pretty stupid, but I'm bored and my old Pi wasn't seeing much use, not sure if this is even relevant or anyone here can help me. Using it as an automated CO2 brewing/gasing system. Using a CO2 cylinder, required a hose to connect all the fittings, but the fitting I got came with an incorrect size on the cylinder side. It's a standard Australian cylinder Type 30 (w21-8 I believe), however, the fitting I received was a CGA320/G1/2 (and I cannot replace the fitting with a 1/4" type 30 nut because of the way the hose is fitted)
Just asking for help to try find a Female Type 30 to Male CGA320, anything I have come across has been Female CGA320 Male Type 30 or only specifies one of the heads. This (#3) is the closest thing I have been able to find, but they haven't had the product available in a while now. Thanks for any help with this, all the other brewing forums I tried visiting for help are either archived or haven't had any activity in over 3 months (Australian forums, haven't tried international because apparently, CGA320 in America is different from here).
Nothing overly expensive if it can be helped, thanks for any help.
Amazon.com will not ship to Australia due to the imposed tax, so it cuts out a lot of options from there. That adapter, however, possibly has the correct Female end (Type30 and G1/2 / CGA320 are often listed as one and the same but are not, Type30 can seal on CGA320 with sealing tape, but CGA320 female will not fit a Type30 Male), but does not have the correct Male end, instead using the European counterpart with the TR21-4 head.
I assume no one else could either 🙁
You have a very specific "ask" and something outside the areas of interest the site typically serves.
Since Amazon isn't an option for you, what other sources might work? That info may help (an)other member(s) to offer suggestions.
Is Aliexpress an option? https://www.aliexpress.com/i/33053360628.html (note the variations listed, not necessarily the linked item itself).
Amazon is simply because they will not ship to Australia and Australia's amazon is nothing but 90% markups on a very limited selection of items. aliexpress is fine, albeit with no guarantee of the quality of the product. Found someone on Fiverr who would be willing to make one with their laithe however, might be the easiest solution.
Sounds like a good solution. Good luck.
