Help Finding A Decent Case
TehNinjaCat
115
Hey Guys, As The Title Says, In 0-2 Years Time, I'm Probably Going To Build A New PC, And If You Guys Could Find A Decent Case That Would Be Awesome :)
What It Needs:
To Be Able To Fit These Parts -
Intel i5 3570k
Asus P8Z77 Mobo
8GB Vengeance RAM ( I Know These Parts Go On The Mobo But Adding Just In Case It's Needed)
Nvidia GTX 660 Twin Frozr OC Edition
Corsair CX600W
Good Cable Management
Preferably Bottom PSU Placement
Good Ventilation, Case Fans Ect.
Ill Edit Below Here If I Think Of Anything Else :)
Budget Is Nothing Over £100 Really :) ($160)
99% of cases out there will fit all those components.
It is difficult to recommend a case as there are MANY on the market and people have different taste in design, how it looks and budget.
What I can recommend is to watch some unboxing videos where most details of the case is explained and pros/cons listed. Have a look here: http://www.youtube.com/user/LinusTechTips/videos?query=unboxing+case
Cases I like are:
-Antec P280 http://www.antec.com/product.php?id=704504&fid=6&lan=us
-Coolermaster Cosmos2 http://www.coolermaster.com/microsite/cosmos_ii/design.html
-Corsair 550D, 650D, 500R, C70 http://www.corsair.com/us/pc-cases.html
-Fractal R4 http://www.fractal-design.com/?view=product&category=2&prod=100
-LianLi A71F (mine)...
Cases I like are:
-LianLi A71F (mine) http://www.lian-li.com/v2/en/product/product06.php?pr_index=338&cl_index=1&sc_index=26&ss_index=66
I'll Watch Some Of Them Videos :)
