[SOLVED] Help finding a gaming case?
Pepsi_Man
71
I need three USBs ports.
One for the wheel, the shifter, and mouse.
The box on my k70 keyboard say it requires a usb 3.0.
Can anyone point me in the correct direction?
Motherboards generally have more then 4-6 ports on the rear. You can also just get a USB hub and run all your devices off of one port. All going through the same controller chip in most cases, so there is no performance difference.
Probably requires USB 3.0 because the keyboard itself acts as a USB hub, keyboard communications generally only require USB 2.0. Either way, the solution above will take care of it and probably be preferable to plugging all the mess into the front of the computer.
Reactions: Pepsi_Man
