1. What Is Your Country Of Origin? USA
2. What do you plan to do with this monitor? Gaming, and normal browsing. (Some Netflix)
3. What resolution and screen size do you want? Looking for a 27" IPS (Curved) preferably 1080p a 5ms response time would be a great plus.
4. What refresh rate do you want? 60hz+
5. How much are you looking to spend? About $300~ (Max)
6. Brands Preferred? Anything except MSI I'm willing to look into. (Had some bad experience with their monitors)
7. Are You Buying More Than One Monitor? No
8. How Many Displays Can Your GPU Support Maximum? I have the GTX960M (I believe it can support 4)
9. What Port Do You Want To Connect To (ex. DVI-D, HDMI, etc). Preferably HDMI
10. Is This Monitor A Primary Display Or A Secondary Display? It's gonna be hooked up to my laptop, but I am going to build a Desktop in the next couple of months.
11. Is This A Secondary Display For A Laptop? At the moment, yes.
Thanks in advance!
Thanks in advance!
