Help finding best USB Front Panel
Gareth Johnstone
27
Hi guys,
My case (NZXT Phantom Full Tower) only has 2 USBS (1x USB 3.0 & 1x USB 2.0) on the top/front of the case, I want to use my empty 3.5" bays to expand it using a USB "hub" but I'm not to sure which one to get, preferably the hub has
  • - USB 3
    - USB 2
    - Fast charge USB
Thanks in advance guys!
There is 3 x USB 3.0 which can work as USB 2.0
and 1 x 2.4A usb charging port
http://www.amazon.com/AVANTEK-5-25-Inch-Charging-Charger-Tablets/dp/B00PTOAAO8/ref=pd_sim_147_9?ie=UTF8&refRID=1GGKD3J1Y518MGWFJJ89
This is a 5.25" drive
You would need to use your motherboard USB 3.0 header with this drive , making your case USB 3.0 ports useless
Also you need a sata power cable from your PSU
That's all .
