[SOLVED] Help Finding Flip Phone: $120 or less, unlocked, 4G, nano SIM, T-Mobile compatible?
Chris Fratach
Commendable
Feb 15, 2020
15
So far I've found the Schok Classic Flip and Nokia 2720 Flip.
I believe they meet all my criteria, but aren't sure which is best.
The Nokia is slightly above my price limit, so I'm leaning towards the Schok.
I've also found the Kazuna eTalk and Alcatel GO FLIP 3, but none unlocked...
Any advice or suggestions, right now I'm considering buying the Schok on Amazon.
G networksLocation? A lot o phones are 4G compatible in euorpe but don't work on American 4G networks
Reactions: Chris Fratach
I have a Doro 7050 which I bought from consumer cellular for $50.
I think I'll get the Link from Consumer Cellular... it requires I pay for the first month and two days of the second month... but the phone is $25 refurbished... I wish I could just buy it outright without needing the plan to unlock it though.
I do not know, about the refurb unit, but I doubt it.
They also have a cheaper unit, but I was advised by the target rep that it was not as good.
I called CC, they said anywhere I buy their phone it will be locked, so that rules out getting the Link unless the 7050 is also locked, I'll call Target tomorrow. If it is also locked then the Link is the cheapest, $25 for phone and $15.50 for plan plus taxes.
Thanks.
