Question Help Finding Replacement Panel QNIX QX2710LED
robax91
882
245
The panel itself is cracked, but the front layer and back-light layers are intact. I think it would be best to just replace the entire panel/backlight assembly as I do not have the skill to separate them without damaging the new one. I need help finding what panel I need and where to buy it. I'm in IL, USA but I can work with importing stuff. This break came at the worst time when monitors are very expensive/scarce so if I can find a replacement panel for less than $120 (usd) I would rather do that than have to buy an overpriced monitor. Plus I'd rather save it than contribute to e-waste. Any help would be appreciated.
