Question Help finding the right monitor
Apr 22, 2020
23
I'm looking for a new monitor, but I'm having a hard time finding one with the right height. I need built in audio, ideally less than $600 and am looking for it to be no more than about 34 inches in width.
The ones I've been looking at are generally around 32.52 (W) x 14.57 (H). I like https://www.bestbuy.ca/en-ca/produc...esync-gaming-monitor-34wk650-w-white/13364601
However, I would love one with that width but about an inch or so taller. But as soon as they get a bit taller, they also get significantly wider, or unreasonably expensive. Is the ratio I'm looking for just not available, or am I missing something here?
Youve got to remember that the aspect ratio means that the width will change with height. On a normal 16:9 ratio monitor, changing the height by about an inch will cause the width to change by about 1.5 inches
