Hi there,
I've been looking around for a microsd card that can not only be. accessed by the device it is plugged into but with built in wireless capabilities so that files on it can also be viewed and edited on another device wirelessly (Bluetooth or wifi would both be fine)
I have found a few but all that I have looked at are designed for cameras and only support certain photo file formats. All the ones I have seen also only support downloading and viewing of the files but no way to edit or delete the files on the sd.
If anyone here knows of any such sd I would be very thankful!
Thanks in advance!!
Thanks in advance!!
