Build Advice Help: First build, comments & improvements
MikeDNK
5
Greetings from a humble rookie,
This is my first time building a PC; I would very much appreciate if you could have a look at the parts I have picked, let me know whether they are all compatible but also particularly if there are better choices available for certain parts (PSU?). Furthermore, if you have any more general comments or advice I´d be happy to hear it!
I am based in Thailand, so access to parts is somewhat limited - the main vendors to my knowledge are JIB, BananaIT and InvadeIT. My budget is ~43000THB.
Thank you so much for any feedback that you can provide; I sorely need it and it is much appreciated!
PartNamePriceNotesLink
CPUAMD Ryzen 5 3600
6890​
https://invadeit.co.th/product/cpus-processors/amd/ryzen-5-3600-with-wraith-stealth-cooler-p043678/
GPURed Devil Radeon RX 5700XT
14990​
https://www.invadeit.co.th/product/video-cards/powercolor/red-devil-radeon-rx-5700-xt-8gb-gddr6axrx-5700xt-8gbd6-3dhe-oc-p044354/
PSUCorsair RM650
3500​
Arbitrarily picked this; could I find something better?https://www.invadeit.co.th/product/power-supplies/corsair/rm650-650-watt-power-supply-80-plus-gold-atx-psu-cp-9020194-na-p047674/
RAMG.Skill Trident Royal 3600 2*8gb
5250​
Picked these mostly because they were the only ones listed as compatible on the MSI website*
Is a better choice available?
https://www.invadeit.co.th/product/memory/g-skill/16gb-trident-z-royal-rgb-ddr4-3600mhz-cl18-silver-2x8gb-p042112/
MoboMSI B450 Tomahawk Max
3590​
Compatible?https://www.bnn.in.th/hardware-diy/mainboard/socket-amd-am4/4719072659226?gclid=CjwKCAjwwYP2BRBGEiwAkoBpAqm_KnGwoX3mBVhbkE0gMQ1uPixsbTfSStiZzG5gDSDTEmoCBgDQ0xoCT4AQAvD_BwE
SSDAddLink S70 512gb
3150​
https://www.invadeit.co.th/product/solid-state-drives-ssd/addlink/512gb-s70-m-2-2280-pcle-gen3x4-nvme-ssd-p042142/
HDDSeagate Barracuda 2TB 7200 256mb
2090​
https://www.invadeit.co.th/product/internal-hard-drives/seagate/2tb-barracuda-sata-iii-3-5inch-256mb-7200rpm-st2000dm008-p040646/
CaseThermaltake Commander C34 TG
2800​
https://invadeit.co.th/product/computer-cases/thermaltake/commander-c34-tg-argb-snow-mid-tower-case-fits-atx-with-tempered-glass-white-p045674/
Total
42260​
*) Link here
Captaingadget
278
13
4,915
49
Looks fine to me, PSU is good, good CPU/GPU balance and on the website you've linked it says that B450 is Ryzen 3rd Gen ready so should work with the 3600. You've got fast RAM, which Ryzen likes. Not sure about the quality of your SSD, I'm not familiar with that brand, but depends if you can get a Crucial/Intel/WD/Samsung for sensible money.
