Help first build
psp_man13
71
tell me if this build will work
PLEXTOR Black 22X DVD+R 8X DVD+RW 8X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827249043
COOLER MASTER Storm Sniper SGC-6000-KKN1-GP Black ABS Bezel, SECC Body ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119194
Scythe KM02-BK 5.25" Bay Fan Controller
http://www.newegg.com/Product/Product.aspx?Item=N82E16811998055
Western Digital VelociRaptor WD3000HLFS 300GB 10000 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136322
ASUS VH226H Black 21.5" 2ms(GTG) HDMI Widescreen 16:9 Full HD 1080P LCD Monitor 300 cd/m2 1000:1 (ASCR 12000 : 1) Built in Speakers
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236051
CORSAIR CMPSU-1000HX 1000W ATX12V 2.2 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS Certified Modular Active PFC Compatible with Core i7 Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139007
Microsoft Digital Media Pro BX1-00005 2-Tone 105 Normal Keys 22 Function Keys + 1 Zoom Slider Function Keys USB or PS/2 Wired Standard Keyboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16823109137
Microsoft N71-00007S Black 3 Buttons 1 x Wheel USB Wired Optical Wheel Mouse
http://www.newegg.com/Product/Product.aspx?Item=N82E16826105026
CORSAIR DOMINATOR 3GB (3 x 1GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model TR3X3G1600C8D
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145225 x2
ASUS P6T LGA 1366 Intel X58 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131359
Thermaltake A2018 120mm Blue LED Case Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16811999122 x4
COOLER MASTER V10 Hybrid TEC RR-B2P-UV10-GP 120mm CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103056
Arctic Silver 5 Thermal Compound
http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007
Nippon Labs 6 ft. HDMI TO HDMI A/V Gold Plated Cable Model HDMI1.3-6
http://www.newegg.com/Product/Product.aspx?Item=N82E16812816002
SAPPHIRE 100269SR Radeon HD 4890 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102830
Intel Core i7 920 Nehalem 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
price $2,016.77
overclock 3.2 to 4.0 ghz somewhere around there
will the memory and the cpu cooler work
will this motherboard overclock that high and will the fans cool good for that kind of overclock and no watercooling
will 2 of the GPUs crossfire and play any game in 1080p and maybe when the ati radeon 4890 x2 r here i can do quad gpu or 3 way gpu crossfire
i will add raptors and my goal is 4 raptors raid 0 and 1 2tb wd drive
and i will add blu-ray later
V10 is a waste of money. Go for the Noctua NH-U12P SE1366.
+1 on the 850HX
The VRap is also a waste of money, go for the WD6401AALS, it will be almost as fast, twice as large, and a third the price.
i will go for the ram thanks but the mobo i will go with asus and the power supply yes the only thang i see between the 2 is 1 more cpu 8 pin power
Where? I haven't seen anything to that effect. From what I have seen, the V10 is barely better than the $40-$50 coolers and weighs twice as much, putting much more strain on the MB and increasing the chance of damage if you move the computer around.
the computer will stay in 1 spot for most of the time if i move it i will turn it off and remove it but i want to know if i remove it will i need to replace the thermal compound and the case i have i can remove it and dont have to take the mother board out
SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151171
Western Digital VelociRaptor WD1500HLFS 150GB 10000 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136296
Saitek PZ30AU Black 104 Normal Keys 4 Function Keys USB Standard Eclipse Keyboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16823175103
Logitech MX518 8 Buttons 1 x Wheel USB Wired Optical 1800 dpi Gaming-Grade Mouse
http://www.newegg.com/Product/Product.aspx?Item=N82E16826104178
CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model TR3X6G1600C8D
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145224
Intel BOXDX58SO LGA 1366 Intel X58 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813121361
ZALMAN CNPS10X Extreme 120mm 2 Ball CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118051
Antec Nine Hundred Two Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129058
Antec EA750 750W ATX12V version 2.3 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC "compatible with Core i7" Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371026
V10 review:
http://www.overclockersclub.com/reviews/cm_v10/4.htm
http://www.xtremesystems.org/forums/showthread.php?t=216567
What I'm seeing here is that the cooler only really shines at higher temps, holding those down better than air coolers.
If you want to save some money, get this proven air cooler:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835185093
And as I said before, the Corsair Dominator RAM is overpriced. The OCZ kit I linked will work fine.
Don't use Intel motherboards. They are quite gimpy.
I would go with your first build over your second build & take into account everyone's comments. We are trying to help improve upon your build.
Example: WD 640 instead of the WD 300 VRaptor. The 640 cost roughly $75 vs $225 for the VRaptor for close to the same performance. The group is trying to get you the best / better performance for equal or less money.
Example: 850TX vs 1000HX. You would be better suited with the 850TX, instead of spending more on a PSU wattage you don't require.
Give these some thoughts... :). You are way ahead of where I was at 15 but of course my super computer was a Commodor64 at that age :)
Intel motherboards don't overclock well, if at all. They also have had quality issues in recent years, perhaps because they don't sell many.
Gigabyte and Asus are the two brands you want to stay with for motherboards.
how about that it looks better
Western Digital Caviar Black WD5001AALS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136320
CORSAIR CMPSU-850HX 850W ATX12V 2.3 / EPS12V 2.91 Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
OCZ XMP Ready Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Low Voltage Desktop Memory Model OCZ3X1600LV6GK
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227388
Antec 761345-75024-0 120mm Blue LED Case Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835209011
