This is my first time watercooling and need as much help as I can get
These are my parts sofar
Case Fan: Noctua NF-F12 PWM 55.0 CFM 120mm Fan ($23.99 @ SuperBiiz)
Other: Raystorm CPU Block ($66.98) http://www.frozencpu.com/products/14186/ex-blc-971/XSPC...
Other: GPU Waterblock ($128.99) http://koolance.com/video-card-vga-amd-radeon-r9-290x-w...
Other: 360 Rad ($69.95) http://www.frozencpu.com/products/5069/ex-rad-93/Black_...
Other: Reservoir ($59.95) http://www.frozencpu.com/products/14261/ex-res-319/Bits...
Other: Pump ($79.99) http://www.newegg.com/Product/Product.aspx?Item=N82E16835108082
Other: Compressions x8 ($55.92)
http://www.frozencpu.com/products/8099/ex-tub-423/Bitsp...
Other: Red tubing ($18.99) http://www.frozencpu.com/products/17873/ex-tub-1606/Pri...
I will be using distiller water and a kill coil
Is this setup good for a CPU and Gpu, Pump/Res>Rad>CPU>Gpu>Reservoir
If I'm missing anything can you tell me
Side note I plan on over locking the CPU (4770k) as far as possible and same with the Gpu (r9 290)
