Hello Tom's Hardware friends,
I am new to PC building, but finally investing in a desktop after years on laptop. While I've consulted all of Tom's Hardware's guides for building a gaming PC, I could use a 2nd opinion in case of any glaring errors.
Approximate Purchase Date: Today/This weekend (Sept. 1)
Budget Range: $2000
System Usage from Most to Least Important: Gaming (Starfield, Fallout 76, etc.) and recording
Are you buying a monitor: No
Do you need to buy OS: Maybe? I was going to make a Windows 10 boot USB
Preferred Website(s) for Parts: NewEgg
Parts Preferences: Below is the setup I've assembled based on Tom's Hardware guides and NewEgg's compatibility check:
CPU:
GPU: - this one is currently on sale today only.
Cooler:
Motherboard:
Memory:
Storage:
Power:
Case:
Overclocking: Maybe (again 1st time, not planning to start with this.
SLI or Crossfire: Maybe - I've not considered this in the selection.
Your Monitor Resolution: 1920x1080
Additional Comments: I picked my case because it has a nice window panel and orange highlights, which I really like. I do like the customizable LCD for the NZXT cooler as well, but if it's overkill, I'd love to know.
Any comments or advice would be appreciated and thank you!
Budget Range: $2000
CPU:
AMD Ryzen 7 7800X3D - Ryzen 7 7000 Series 8-Core Socket AM5 120W AMD Radeon Graphics Desktop Processor - 100-100000910WOF
https://www.newegg.com/amd-ryzen-7-...series/p/N82E16819113793?Item=N82E16819113793
ASUS TUF Gaming NVIDIA GeForce RTX 4070 OC Edition Gaming Graphics Card (PCIe 4.0, 12GB GDDR6X, HDMI 2.1, DisplayPort 1.4a) TUF-RTX4070-O12G-GAMING
https://www.newegg.com/asus-geforce-rtx-4070-tuf-rtx4070-o12g-gaming/p/N82E16814126637?Item=N82E16814126637Cooler:
NZXT Kraken Elite RGB 280mm - RL-KR28E-B1 – RGB AIO CPU Liquid Cooler – Customizable LCD Display - 2 x F140RGB Core Fans Radiator Fans Black LGA 1700 / AM5 Compatible
https://www.newegg.com/nzxt-liquid-...te-rgb/p/N82E16835146133?Item=N82E16835146133Motherboard:
GIGABYTE B650 AORUS ELITE AX AM5 LGA 1718 AMD B650 ATX Motherboard DDR5, M.2, PCIe 5.0, USB 3.2 Gen2X2 Type-C, WiFi 6E, 2.5GbE LAN, Q-Flash Plus, EZ-Latch
https://www.newegg.com/p/N82E16813145412?Item=N82E16813145412
Memory:
G.SKILL Trident Z5 RGB Series 32GB (2 x 16GB) 288-Pin PC RAM DDR5 6000 (PC5 48000) Desktop Memory Model F5-6000J3636F16GX2-TZ5RK
https://www.newegg.com/g-skill-32gb-288-pin-ddr5-sdram/p/N82E16820374351?Item=N82E16820374351
Storage:
SAMSUNG 990 PRO M.2 2280 2TB PCI-Express Gen 4.0 x4, NVMe 2.0 V7 V-NAND 3bit MLC Internal Solid State Drive (SSD) MZ-V9P2T0B/AM
https://www.newegg.com/samsung-2tb-990-pro/p/N82E16820147861?Item=N82E16820147861
Power:
CORSAIR RM750e Fully Modular Low-Noise ATX Power Supply - ATX 3.0 & PCIe 5.0 Compliant - 105°C-Rated Capacitors - 80 PLUS Gold Efficiency - Modern Standby Support
https://www.newegg.com/corsair-rm750e-cp-9020262-na-750-w/p/N82E16817139307?Item=N82E16817139307Case:
Fractal Design Pop Air RGB Black Orange Core TG ATX High-Airflow Clear Tempered Glass Window Mid Tower Computer Case
https://www.newegg.com/black-orange...-tower/p/N82E16811352174?Item=N82E16811352174
