Help for $700 first pc
fury0609
94
Approximate Purchase Date: idk yet maybe next week but probably after done moving like sept
Budget Range: $700 Before / After Rebates
System Usage from Most to Least Important: gaming, internet
Parts Not Required: need all including keyboard mouse os
Preferred Website(s) for Parts: newegg.com / microcenter.com
Country of Origin: US
Parts Preferences: atleast a radeon hd 6850 or gtx 460
Overclocking: No
SLI or Crossfire: Maybe
Monitor Resolution: 1920 x 1080
Monitor: http://www.bestbuy.com/site/Acer+-+21.5%22+Flat-Panel+LCD+Monitor/2596077.p?id=1218338417745&skuId=2596077
the K version is only $10 more and allows for some combos on newegg so in my build it saved $6. plus this build can be overclocked if you decide to in the future. better to leave some options open. i was trying to fit an I5 in the build you could go with amd or the i3 and get a better mobo and case. I was grasping at straws on the case.
well this is what i got so far
but its a little over budget (like $50 over budget after rebates)
LG CD/DVD Burner Black SATA Model GH22NS70 OEM - OEM
Item #: N82E16827136238
Return Policy: Standard Return Policy
Protect Your Investment (expand for options)
$18.99
NZXT Beta Series CS-NT-BETA-B Black Steel / Plastic ATX Mid Tower Computer Case
Item #: N82E16811146055
-$10.00 Instant
$49.99
$39.99
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822152185
-$5.00 Instant
$64.99
$59.99
SAPPHIRE 100315L Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
Item #: N82E16814102908
Return Policy: VGA Standard Return Policy
-$15.00 Instant
$15.00 Mail-in Rebate Card
$169.99
$154.99
Antec High Current Gamer Series HCG-620 620W ATX12V v2.3 / EPS12V v2.91 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified ...
Item #: N82E16817371048
-$25.00 Instant
$20.00 Mail-in Rebate
$94.99
$69.99
Microsoft Natural Ergonomic Keyboard 4000
Item #: N82E16823109148
-$11.00 Instant
$49.99
$38.99
GIGABYTE GM-M6900 Black Tilt Wheel USB Wired Optical Mouse
Item #: N82E16826146020
$12.00 Mail-in Rebate Card
$29.99
G.SKILL Ripjaws X Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBXL
Item #: N82E16820231427
Return Policy: Memory Standard Return Policy
$33.99
ASRock Z68 PRO3-M LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
Item #: N82E16813157252
-$10.00 Instant
$124.99
$114.99
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
Item #: N82E16832116986
Return Policy: Software Standard Return Policy
-$5.00 Instant
$99.99
$94.99
Subtotal: $656.90
+$149 i5-2400 at microcenter
oh i didnt notice that promo
i think ill get my mobo and cpu from there
heres the mobo i picked
what do you think?
http://www.microcenter.com/single_product_results.phtml?product_id=0364087
plus the i5-2400 total $242 with tax before $15 rebate
*i dont know what is required to sli/crossfire
but that mobo said it supports it and the psu i picked says it is sli/crossfire ready
so does that mean that i can sli/crossfire?
not that im gonna do it but maybe in like a couple of years when i need an upgrade
