[SOLVED] Help for a very old old ms-7301
Dec 7, 2020
9
I need to find the last bios available for my old motherboard Msi ms-7301 but I don't know where to find it....
I'm looking for the .316 bios but I cannot find any file in the web.
Can somebody help me?
Thanks 🙂
Hi sometimes just what you need is perhaps a google search away!
Or is it?! 😵
anyways here is what I could find using google:
https://www.bios-mods.com/forum/Thr...01-Unlocked-With-Overclocking-Options-Slic2-1
BUT
please remember that downloading bios files from anywhere but the original mother board sources is highly dangerous. I know this is a very old motherboard which is no longer supported, but keep the security aspect of things in mind, cause a BadBIOS will get into almost all of your devices that you connect to this motherboard if you get a hardware virus.
Thank you!
Both the links work but I can download the same file: unlocked+slic2.1 bios
If I understand the thread I also need the file: only slic2.1 bios
Do you know where can I find it?
Thank you
Ok, thank you.
As you can understand I'm not very expert....
I will try tomorrow (here in Italy is quite late now)
Thank you again.
PS - sorry for my poor English.....
Ok, thank you.
Thank you again.
Just make 100% sure that is the correct BIOS for your MB Before you flash it.
Here is another link to the 3.16 BIOS with just SLIC 2.1 info added:
Manufacturer: Packard Bell imedia 2579
Motherboard Model: MS-7301
Bios revision: 3.16 (Taken from cuba boot cd)
Bios Type: AWARD BIOS
All SLICs 2.x (Modded Bios List) - Note: For requests use 'Bios Mod Requests' section | Page 145 | My Digital Life Forums
To be honest I was looking for the official bios Microstar for Packard Bell CUBA MS-7301 3.16 motherboard BIOS - 6A7L8M43 but it looks impossible to find It on the web....
I'm in the process to update my bios now but I have a last question: can I use the DOS flash tool for the 'BIOS with Unlocked features for Overclocking and SLIC 2.1 info inserted' also for the 'original' bios or do I have to use a different one?
