Hello the community ✨
I am assembling my first computer.
I am not completely retarded but partly.
This is the fan situation :
- Asus Rog Strix Z390-e gaming board | Headers : CPU_FAN CPU_OPT CHA_FAN1 CHA_FAN2 & M.2 (all Q-Fan controlled)
- Fractal Design r6 case | PWM Fan hub with 3 PWM 4 pin fans & 6 3 pin fans
- Fractal Design r6 case : 3 3 pin fans
- Bequiet : 3 4 pin fans
- Noctua NH-D15s CPU fan (PWM)
- What is the wiring that would allow best control/flexibility over the fan controls, utilising PWM as much as possible, and would make most sense ? ( = where to plug each fan !?)
- The fractal design manual says to plug the PWM hub to the CPU_FAN port. Would it be a thing to plug it to the CPU_OPT port (which I'm not sure what it's for so far), and let the CPU fan be plugged directly into the motherboard on the CPU_FAN ?
- Please help me check if I understood correctly : all PWM fans from the hub will receive the same "speed" message, they are not individual controls, right ? And the 3 pin fans will always go full speed with no control possibility, is that correct ?
