Hi,
I am trying to prepare upgrade to Window 11. I just found out that my Boot Manager and Window 10 are saved in 2 different Hard Disks. I tried to change the boot setting in BIOS to the Disk Window saved but it does not work. It saying error of no boot manager.
Here is some information for my PC, my Boot Manager is somehow under F Drive (It is a Plextor 128GB SSD) and the Window is under H: (C
Drive. (It is under a ScanDisk 240GB SSD). I do have another 3 disk. (E Drive: 4TB HDD, Z Drive: 1TB HDD and D Drive: 1TB NVM) Majority of the program are saved under the H: Drive. I cannot see any other data in F Drive from File Explorer now.
I want to combine or migrate the Boot Manager and Window together into the D: Drive which is empty. After this is done, I will change the F Drive (Plextor SSD) disk format from MBR to GPT. Then, move the whole Window back to F Drive from D: Drive. After everything ok, I will backup and then upgrade to Window 11.
Who can help and tell me how to combine or migrate the Boot Manager and Window into 1 places without a clean Window install? Pls kindly share any idea with me.
Pls let me know if you need any other information.
Thank you very much
Thank you very much
