Help for choosing headset
ZloDete
31
I need help with choosing a headset and i was thinking about getting razer carcharias.Are they good? Do you have some headset to recommend to me(max price 80 euros)?
The Genius Cavimanus for sure! They have Virtual 7.1 Surround Sound, which is GREAT for FPS games and MMO games, HECK it's great for all games AND movies! The only downside would be that they have a 40mm Driver over the SteelSeries Diablo III which have a 50mm, but there shouldn't be a huge differnce in bass, also they have the same size driver as the G230's which means that they will give you practically the same bass.
To over simplify, get the Genius Cavimanus as they have just as good of bass if not better than the G230's and have 7.1 Surround Sound (which should help you hear footsteps and help you decode where they are coming from exactly.
Have fun with the new headset!
~Upstagebuffalo
Personally I have never used a Razor product, however I have heard many bad things about Razor such as that they make very "flimsy" or "weak" headsets. Personally I would recommend a Corsair, Logitech, or Turtle Beach Headset. My recommendation would be to get a Logitech as they are very well known for making quality headsets, I recommend looking at the G35's or the G430's they both have surround sound as well which is very good when playing FPS games. Hope this helps.
~Upstagebuffalo
Well in my country G430 cost 100 euro, and G35 cost like 160 euro so they don't fit in my budget. Are G230 good? I had a post about steelseries diablo III headset,does steelseries make good quality headsets? And if you had to chose between G320 and Steelseries Diablo III which would you chose?
Between the two I would say to go for the SteelSeries Diablo III Gaming Headset. They have a higher frequency response, a 50mm Driver over the 40mm Driver the G230 has (base gets better/louder the bigger the driver gets) and seems to have a fairly good quality microphone.
~Upstagebuffalo
~Upstagebuffalo
