i am planing to buy the following
Gigabyte GA-H97-D3H Socket 1150
or
MSI H97 GUARD-PRO Socket 1150
Kingston ValueRAM 4GB DDR3 1600MHz CL11 1.5V will buy two of them for the dual channel
or
Kingston HyperX FURY Blue 8GB DDR3 1600MHz CL10 1.5v
i5 4440 haswell
Western Digital (WD) Caviar Green WD20EARX 2TB 64MB
gigabyte r9 280x windfroce 3gb i already have it
cooler master exterme 2 525 w i already have it too
* the mobo , ram , HDD and the cpu i will buy thise week i want your opinion about the ram and the mobo which one to get and i am in a very tight budget if b85 mobo is fine then recommend one to me if not then give me a choice of one of what i explained later please thank you
or
or
i5 4440 haswell
