im planning to buy Sapphire R9 270x 2G GDDR5 Dual-X &OC will it be compatible with my GA-F2A58M-DS2 motherboard?also planning to buy Corsair CX600w will this PSU can support R9 270x?
GIGABYTE GA-F2A58M-DS2 Specifications
APU Support - AMD FM2+/FM2 A-series processors
APU Socket - AMD Socket FM2+
Chipset - AMD A58 Chipset
Graphics Interface - 1*PCI-E 3.0 x16 slot*
Display Interface - Dual-link DVI-D/D-Sub
Memory Type - Dual-channel DDR3
Memory Slot - 2*DDR3
Expansion Slot - 1*PCI-E x1 + 1*PCI slots
SATA connectors - 4* SATA2
SATA RAID - RAID 0,1,10
USB - 8*USB 2.0
Audio/LAN - 8-channel HD /GbE LAN
Form Factor(mm) - Micro-ATX (226x174)
Other:
Processor - AMD RICHLAND A8-6600K 4.2GHZ QUAD CORE
Memory Module - KINGSTON FURY BLACK 4GB 1866MHZ DDR3 (1)
Hard Disk Drive - WESTERN DIGITAL 500GB CAVIAR BLUE SATA3 (2)
Graphics Card - AMD RADEON HD8570D Integrated
Optical Drive - ASUS DRW-24F1ST DVD/CD-WRITER 24X DUAL LAYER
Will all the computer parts listed above will run smoothly with PSU Corsair CX600w?
Thanks for the reply in advance
USB - 8*USB 2.0
Other:
