Help for my 1st build ;)
ShmeekYeezy
20
I need help building my first PC. I am looking to make a smooth slow transition from console to PC. I need a PC that can play games on medium high with 50-60 frames. Nothing too big as this is my first build and i want to upgrade in the future. My budget is $400-$500. Please help if this is possible. If OS comes included without going over budget that would really help but if not its not that big of an issue. Thanks 😉
Here is my stock answer for a "budget" build:
------------------------------ budget kaby lake build ---------------------------
For a budget gaming build, I like to recommend that one builds for future expandability.
That means paying a bit more up front for some parts that allow for an easier future upgrade.
A good rule of thumb is to budget twice as much for the graphics card than for the cpu.
Let me start where you might not expect:
1. Buy a good 500w psu or better. 520w will run a card as good as a GTX1080.
Future graphics cards will be built on smaller 14nm so they should not need more power than today.
I would normally suggest Seasonic 520w: Expect to pay around $60.
Look for a tier 1 or 2 quality unit on a list such...
Look for a tier 1 or 2 quality unit on a list such as this:
https://community.newegg.com/eggxpert/computer_hardware/f/135081/t/45344.aspx?Redirected=true
2. Buy a Z270 based motherboard. Z270 will allow you to install a overclockable cpu.
You should find one for under $120. Lesser lga1151 chipsets will work for the truly budget constrained but at the expense of future upgrade optiions.
Here is a M-ATX example:
ASRock Fatal1ty z270M pro 4 for $120:
https://www.newegg.com/Product/Product.aspx?Item=N82E16813157741
If a future upgrade to an overclockable I5-7600K is not likely, you can use a much cheaper B250 based motherboard for about $80.
3. I suggest a G4620 @3.7. About $93. If you are truly budget limited, you can buy a g3930 dual core for $42.
In time, you can upgrade to any I3/I5/I7 cpu that you want and market the original processor.
4. The intel stock cooler will do the job. Skylake runs cool.
If you want, you can use a cryorig H7 cooler with a 120mm fan. $35. It will be quieter.
http://www.newegg.com/Product/Product.aspx?Item=9SIA4UF2DZ6565
One can always add a cpu cooler later.
5. For ram, speed is not important. Buy a 8gb kit of 2 x 4gb DDR4 1.2v 2133 speed ram.
About $40. If you ever want 16gb, buy it up front in one kit; adding more ram is never guaranteed to work.
Heat spreaders are marketing and generally useless.
Faster ram is not worth it for skylake and kaby lake:
http://www.silentpcreview.com/article1478-page1.html
6. Cases are a personal thing. Buy one you love. Most will do the job for <$50.
Here is a silverstone PS08 for $35; It fits a smallar M-ATX motherboard.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163223
7. The graphics card is the most important component for gaming.
I like the GTX750ti and EVGA as a brand.
Here is a superclock version:
You could go stronger in the video card if your budget permits and your games need it.
On the other hand, you could build using the integrated 630 graphics which is quite good and see how you do.
By deferring on the graphics card, you will get a better idea of what you really need.
Integrated is fine for sims, but not fast action games.
8. Lastly, I will never build again without a SSD for the "C" drive. It makes everything you do so much quicker. 120gb will hold the OS and a handful of games.
With 240gb you may never need a hard drive at all. Defer on a hard drive until your ssd approaches 90% full.
Currently, I like samsung 850 EVO best.
-------------good luck------------
Latest posts
