Help for my Gtx 1050 ti !!
Sep 25, 2018
Hello there,
Recently i bought new parts for a new pc like:
-Intel Pentium G4400 3.3Ghz
-Unbranded Gtx 1050 Ti 4gb with vga/hdmi/dvi port and 6 pin power connector
-Motherboard Msi H110M Pro-VD
-4 gb DDR4 samsung ram
-250W Dell Psu
When i assembled all the parts and configured windows everything was okay when i installed the drivers(from Msi website because lost driver disc) i noticed that the graphic card wasn't working properly. When i plugged the vga cable it said no signal but the fans continued working. I tried different methods because my psu didn't have a 6 pin connector so i tried with another external psu but still the same result. I tried different cables and even to upgrade the bios and change the settings for onboard graphic card but still cannot solve the problem. Probably the problem is with the graphic card but i still doubt.
Please i need your help!
Thank you in advance!
Try with a HDMI cable. If that didn't solve the problem, its most probably your PSU causing this.
What are the amps for the 12V rail (PSU)?
I had a similar problem with my GTX 660 TI, turned out my unbranded PSU was rated at 500Watts but only gave 192Watts.
Do 1050Ti's come with VGA?
Sounds counterfeit.
Nope, OP is probably scammed. It is a GTX 550 TI, GTS 450 flashed to GTX 1050 TI BIOS. Where did you bought the GPU and how much did it cost?
