Help for pc build
mihailws
25
A am going to buy a new pc.I made one build myself and i want your opinion for it.
It's my first build and i dont know will it work.Please help.
CPU: I7-4790K
CPU cooler: Corsair Hydro Series Extreme Performance Liquid CPU Cooler H80i
motherboard: MSI ATX DDR3 2600 LGA 1150 Motherboards Z97 GAMING 7
power supply: Corsair RM Series 850 Watt ATX/EPS 80PLUS Gold-Certified Power Supply - CP-9020056-NA RM850
RAM: Corsair Vengeance Pro 16GB 2x8GB DDR3 2400MHz PC3 19200 Desktop, Red CMY16GX3M2A2400C11R
ROM: WD Blue 1 TB Desktop Hard Drive: 3.5 Inch, 7200 RPM, SATA 6 Gb/s, 64 MB Cache - WD10EZEX
optical drive:Asus 24x DVD-RW Serial-ATA Internal OEM Optical Drive DRW-24B1ST
Video card: MSI Computer Corp. Computer Video Graphics Cards GTX 780TI GAMING 3G
case: NZXT Guardian 921 RB ATX Mid Tower Case
I would recommend a Corsair case such as the 400r or one of the ones that badboy recommended. I would also recommend a SSD for a boot / application drive such as an Intel SSD or a Samsung EVO 840. You could then use the HDD for storage. If you get a SSD you could also look at the different storage options that Z97 provides such as M.2 flash storage.
If you wish to get more fans then I would highly recommend the Corsair SP120 quiet editions fans. They produce fantastic static pressure. You could use them on your rad cooler and for your case fans.
If you would need a splitter to fill out your case with fans, I would recommend the PWM splitters from Silverstone.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812162026&cm_re=pwm_splitter-_-12-162-026-_-Product
Great choice on the MSI board as well. I am huge fan of MSI boards and have used multitude of them in not only my own build, but other builds as well.
