Help for Ram settings Q6600 , P35-DQ6 , KHX8500D2K2/2GN Rams
nasgod
Can somone help me with the settings of my mobo Gigabyte P35-D-Q6
CPU : Q6600
Ram : KHX8500D2K2/2GN 2GB kit DDR2 1066MHz Non-ECC CL5 (kit of 2 - 1GB) 5-5-5-15 2.2V
Ram is now running on 4:5 333Hz 5-5-5-15 is this correct ????
When i put everything to auto then i get errors in Memtest test#5 at 98%
Is this normal ? When i test them one by one at 1066Mhz they don't give error's
5-7-7-24 at 2.2V 533Mhz
url]
url]
url]
I ran test #5 - 4 times and didn't get any error's
Are there other programs i need to run to know if this config is save ?
you need to disable speedstep / EIST. You dont want it monkeying around with your clock speeds or multipliers while you are testing, you want it to be running at full speed all the time. When you know its stable then re-enable that powersaving stuff.
Also, I'd set that RAM to run at at least 2.2v, if not 2.3.
