C cutesydani Reputable Dec 7, 2014 2 0 4,510 Jan 22, 2016 #1 Hello I have a Foxconn g41m motherboard. The specs say that if it is 64 but it can hold 8gb. I upgraded to 64 bit but it will still only hold 4gb, anything more and computer won't run.
Solution C C Calvin7 Jan 22, 2016 2 x 4GB DDR2 kits are not inexpensive. If you install the wrong memory, which you don't list, the computer won't run. 8GB (2 x 4GB) PC2-5300 DDR2-667MHZ 240Pin UnBuffered DIMM Desktop RAM Memory http://www.newegg.com/Product/Product.aspx?Item=9SIA5752CF3289 Crucial 8GB (2 x 4GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Desktop Memory Model CT2KIT51264AA667 http://www.newegg.com/Product/Product.aspx?Item=N82E16820148274 Mushkin Enhanced Silverline 8GB (2 x 4GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Desktop Memory Model 996757 http://www.newegg.com/Product/Product.aspx?Item=N82E16820226358
Petrossa Splendid Jan 30, 2014 2,629 11 27,565 Jan 22, 2016 #2 Would be helpful if we knew which model board it is and which revision of that model. Upvote 0 Downvote
C Calvin7 Titan Feb 19, 2013 11,722 336 76,490 Jan 22, 2016 Solution #3 2 x 4GB DDR2 kits are not inexpensive. If you install the wrong memory, which you don't list, the computer won't run. 8GB (2 x 4GB) PC2-5300 DDR2-667MHZ 240Pin UnBuffered DIMM Desktop RAM Memory http://www.newegg.com/Product/Product.aspx?Item=9SIA5752CF3289 Crucial 8GB (2 x 4GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Desktop Memory Model CT2KIT51264AA667 http://www.newegg.com/Product/Product.aspx?Item=N82E16820148274 Mushkin Enhanced Silverline 8GB (2 x 4GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Desktop Memory Model 996757 http://www.newegg.com/Product/Product.aspx?Item=N82E16820226358 Upvote 0 Downvote Solution
